I am having problems with my sons bike. It was running great until recently. On the weekend he was riding it and it started to bog out, I noticed that the choke lever was moving with the vibrations of the motor, and the bike was being choked. I bent the choke lever a little so that it stopped moving and I thought the problem was fixed.
After about 20 minutes the bike just died. It seemed like it over heated, it was really hot. He had only been riding for about 30 minutes total.
Now I can't get the bike to start! I have taken the carb of and cleaned it. If I put gas down the head the bike still won't start. The bike has spark and I put a new plug in too.
I checked the compression using a gauge and held the throttle open and pulled the bike over 3 times, the psi was 75. Is that good compression? Did I use the correct method to test it?
I am using gas mixed 25:1 with stabilizer in it.
I don't know what to check next?
