MichiGator
- Jun 23, 2003
- 12
- 0
Hey gang,
I just bought a Type II DG silencer for my old KDX as the old silencer had seen better days. My problem is this: The old rubber mounts for securing the original silencer to the frame aren't even close to the correct size for the new DG silencer. I had to fabricate with some old Rubber grommets I had laying around, but now the silencer is so close to the rear fender it is starting to melt it. I called DG and they said to use the old rubber mounts-they should fit fine. They arent even close! I must not be the only one who this has happened to. Any info would be helpful. I guess I'll just have to grab some rubber washers and do a little spacing. (Exhaust note Sounds a little better though!)
