hey guys, soooo I've started hooking humpty dumpty here all back together again...I thought I had the wiring done correctly, but I have no idea right now. I'm calling it quits for the evening but thought Id get whatevers fresh in my mind out here so as not to miss anything. Basically, I wired everything up like the diagram shows...at least I'm 98% certain I did.
Anyway, I put some plastics back on, and go to start it....and it just isn't starting. It sounds like he wants to, but he just won't seem to turn over. At the moment, all I have to show for it is a good sized bump and a few scraps on my chin...ughhh.
So heres a few questions going through my head....
There are basically 3 hoses running from the carb, down towards the ground...and not one of em are hooked up to anything. I don't recall disconnecting any of those, but then just cause I don't remember it doesn't mean I didn't. Are these supposed to be like air intakes into the carb or something or what? I'm a bit confused about those. One is sort clear with a yellow tinge to it, the other two are clear with a sort of redish tinge to them.
Next I should mention that I haven't actually hooked the wires up to the light switch. Or the horn. My thinking on this was that since solder was gonna be involved, and those terminals are so tiny, I woul djust hook the wires together first to see if they wee hooked properly before actually plugging them into those tiny terminals.
At any rate, I seem to get a bit of flicker with two of the three hooked up, and for whatever reason I tried connecting all three together, and that seemed to produce a bit brighter flicker as I tried to fire the bike up.
Couldn't really tell what was happening with the brake lights, since they've got that thick red plastic on em and were only talkin a little flicker right now.
And that, basically is where I'm at right now. I know that info isn't of a whole lot of help, but I figured I might as well start the dialog now while the memory is fresh.
I'm puttin it up for tonite. Lookin forward to hearin from ya'll. Thanks!
