Okay for the track, what year of KX exhaust fits those bikes? It does have a FMF Fatty pipe which list for the 92-93 year KX. But each year 91-93 has a different pipe. no fun!
Matt, I did not realize any KX250 pipes fit on the KDX250. You are right that FMF shows the same part # for the'92-93 KX Fatty as they do for the '91 - '94 KDX250.
Depending on what type of power delivery you are looking for, I would consider chaning your stock silencer/spark arrestor and keeping the FMF fatty. On mine, I used an old Answer SA Pro spark arrestor modified to fit from an 89-94 KDX200.
I used to run the FMF/Answer combo on the trail, and the quieter stock silencer and pipe on dual sport rides. With the aftermarket system, the bike revved out farther and did not have an abrupt low/mid hit (jetting and other engine mods were not changed w/ the pipe switch) that was present with the stock system.
Thanks for the reply dave. I have the FMF turbine II core setup out back with the SA. The guy I bought the bike from had just a silencer on there on the pics of the pic he showed me. I just wanted something low profile for the track. You can pick them up new off ebay for like $30.
I emailed FMF today to see if I get a response back. Hopefully.
Good luck getting an e-mail resonse from FMF :silly: I've emailed them several times and never got the faintest hint of an answer.
If you are not concerned about S/A and noise, it would be interesting to see what a KX250 'silencer' could do. As far as I know, the 91-94 KDX 250 engine is based on an '88 - 89? KX, but the frame is different, so it was interseting to see that the '92-93 KX pipe has the same mounting points.
You can see the pipe and mounts are just a bit different. I am hoping to have like a low profile muffler for the track and keep the SA in good condition for the woods.
