xsnrg
- Jul 20, 2004
- 728
- 0
I ride a '91 KDX250 and my only complaint is that the rear brakes are extremely touchy and lock-up quickly, often stalling the engine (despite the heavy flywheel weight of the 250). Usually it is an issue mostly on long downhills with loose traction, but recently I tapped them on a slight uphill with some slick clay and the instant the breaks started catching, they immediately locked and stalled the engine.
I've searched the FAQ and read all the Search hits for Brakes on this forum...but I've yet to find a conclusive solution to this problem. Below I'll pull together most of the suggestions I've seen elsewhere and pose some questions. Please let me know which of the following suggestions you would try in order...
-> sand the pads
-> spray brake cleaner on the pads (may be contaminated)
-> replace the pads (with softer pads)
-> replace brake pins (scratched, damaged, corroded) with aftermarket pins. (and be careful not to strip or break during removal as many threads discuss).
-> bleed the lines using the many known methods
-> replace the brake fluid with a higher quality DOT 3/4 fluid, but not DOT 5 because it doesn't mix well
-> replace the caliper
-> Is there a complete swap option (KX, later model KDX, other brand/make, or aftermarket) that will upgrade to a better peforming brake (perhaps later technology)
Please order these steps to try to remendy this specific problem and propose any new ones or other inputs. If anyone successfully solved this issue, please tell what did the trick!
I am headed to the Hatfield-McCoy trails soon and don't want to tackle those hills without a fix!
Thanks!
-> sand the pads
Thanks!
