should the rod be easily turned from the lower case to the govener screw in the head? I just rebuilt the top end and ALL the exhasut parts in the head. They were wasted on the bike I just got (as in most cases) I have the factory manual, however it does not tell if this rod should easily twist, nor does it tell how to test this circut !! Before I start it up I would like to know if This rod should move freely while not running. I do know that the advance is in the upper 6000 rpm range.
