SpectraSVT
- Apr 17, 2002
- 720
- 0
I need to know how the Rm is supposed to run, powerband wise. I know its a midrange only bike but I need more info. My buddy has one and I don't know how its supposed to be so its hard for me to trouble shoot. I have searched a couple posts and the jetting seems to be similar to what a couple other people are running.
The powerband is short obviously but its inconsistent. Its either on the pipe or not. Even if the revs are similar, as soon as I let off on the throttle than get back on it immediately afterwards it has fallen off the pipe already. It takes only 1 second for this to happen. Its really hard to ride. Either its pulling crazy hard or not at all. No in between. If I'm steady on the thottle it won't ever get on the pipe. I have to open it up and clutch it to get it to take off.
Jetting is 178 Main with clip in 2nd...55 pilot with air screw at 3 turns out. It was originally at 3rd clip but it bogged if I let off the throttle. Also at 3 turns out I thought I would try leaning out the pilot but that made it run bigtime lean and rev out at 1.5 turns on airscrew. It won't idle either. It starts to settle in then all of a sudden it will bog and die. When its warmed up, if I chop the throttle it will bog first and only rev up if I hold it open a bit.
Its has new top end, new reeds and new silencer packing. I don't know what to do next. I've read 3 jetting guides and nothing is helping me out. My buddy oils the crap out of the air filter so I'm thinking that might be a problem. And I am unfamiliar with the powervalve. It lookes like its set at 1:00. I don't know which way opens or closes it.
PLS let me know how your 93-95 runs so I can figure out if something is wrong or if the bike is just a lightswitch...off or on.
