ml36
125
does anybody know anything about these bikes? i'm having a really hard time getting it to run right. it loads up and fowls plugs when in tight woods and will not even come close to trying to idle.
KTM Mike
2,086
the magic of #7 slide and straight taper needles!
I am far from an expert - am only passing on what I learned from Strick here on DRN and James Dean over on the Holeshot KTM jetting forum -
I had same problems, right off idle and low speed riding bike would load up and foul plugs- the #7 slide and straight taper needles as suggested absolutely corrected it - now my plug reads about perfect no matter how i am riding be it WFO, just off idle or in between. As my bike is a 300 my specific jetting wont likely apply nor would my specific needle - but it is the way to go in my book. Messing with Pilot jet, main jet and clip position never really touched the real problem area. (did end up going back up a couple jets after the slide and needle though)
Strick - got any specifics for the 360?
James Dean
137
'96 KTM360EXC Jetting
Try a Honda needle R1369NS or R1370NS from a '92-'97CR250/500.
Expect jetting to end up as something like:
#48 pilot
1 1/2 turns
R1369NS#3
Stock main jet (#172?)
Your plug fouling days will be over provided the bike is in good running condition. Cleaned your air filter lately?;)
James
Patman
Pantless Wonder
In addition to the specs James Dean supplied be sure you have replaced the stock exhaust (both pipe and spark arrestor) as the stinger section is too small, I used a FMF Gnarly and Turbine Core setup I got from MXTuner. Also the reeed spacer which is an aluminum plate you can get from your dealer will help a bunch. Some folks swear by the compression release hole drilled in the cylinder as a way to end stalling problems. Also some early '96 bikes had a casting number of "1" on the head and later bikes had a lower compression head with a "5".
ml36
125
i don't have the cash for a new exhaust. should i be able to get the bike to run right with the stock exhaust?
patman - can you elaborate on the compression release hole
Patman
Pantless Wonder
I doubt you'll get the bike to run completly right without the exhaust. It was a serious design flaw that cripples a really awesome bike.
The compression hole is a hole drilled in the barrel. I do not recall the exact specification right now but this is not a do it yourself with a hand drill type of modification. There are several shops that can do the modification for you but to be honest save the money and get the exhaust first.:)
pedesktm
26
I had similar problems as you with my 96 360 E. As Patman stated, the earlier cylinders were stamped with a 1. These cylinders were of the higher compression and are difficult to jet. James dean has provided the cheapest way to correct the jetting problems. I also did the Rad valve, FMF exhaust, and reed spacer thing on my 360. I was able to get it to idle and not foul plugs with a very similar jetting set up as James Deans describes. If you are using the stock exhaust, when was the last time the packing was replaced? If it is running as rich as you desribed and it's 4 yrs old, the packing may be saturated with spooge. That will impact performance as well. When you get this thing right and get a clean running bike, you will be smiling from ear to ear. Gobs and gobs of low end billy goat torque that will rev to the moon. You wont be asking, "how fast is this thing" but more on the lines of " I hope I have enough room to stop this thing!!" I'm smiling right now thinking about those fire road drag races!! Good luck.
Rick
99 300 EXC
96 360 EXC Memories
James Dean
137
Needle Alternatives-
You can get a close equivalent to the Honda needles in CGK(1369N) and CGL(1370N) from Sudco for $5 each. (1-800-998-3529) Give it a try, it is easy and inexpensive.
ml36
125
well, my 360 has been sitting for pretty much a year know, and i have finally decided i'm going to get it running. i have a few questions.
james - you did not say anything about the #7 slide. in your opinion is it needed?
patman - what kind of needle are you using? i did try running non-resistors plugs for awhile when i was riding the bike. does this fry the coil or the stator, or something else?
i still have the stock exhaust on the bike. but, i just need to get the bike running well enough that i can sell it. the last time i rode it, it was running very poorly, wouldn't even clean out.
what do you think i can get out of it? it has all new plastic and seat cover and a fresh rebuild.
Patman
Pantless Wonder
I don't remember what needle for sure and I sold the bike. DON'T use non-resistor plugs you WILL toast the ignition module!!! The bike will never run close to right if your keeping it choked with the stock exhaust and don't have the reed spacer in place. You MIGHT be OK with the spacer & #7 slide but it will still not run clean. I sold mine for $3K with a fresh piston & rings, Eric Gorr porting and power valve setup, full MX-Tech suspension, FMF exhaust, and it was in perfect condition.
