freightrain
- Nov 17, 2004
- 19
- 0
I went for a ride yesterday and I came across a mudhole that was way deeper than I expected. The water came up to the seat and the bike died. :yikes: I dragged it out and walked it back to the truck. I emptied out the pipe, pulled the plug and flipped the bike to pump the water out of the cylinder. I also pulled the air filter and let that dry out. I tried to flush the engine out with fuel before kicking it over. I replaced the plug and started kicking. After about 10 minutes of kicking, it fired up. It sputtered a little at first and then ran perfect. I checked the gear oil to make sure it didn't get contaminated, but it was fine. I replaced the air filter afterwiping out the airbox. After I got it all back together, I took a couple of laps and brought her home. The bike ran perfect when I shut it down. Is there anything I need to do before riding again? I assume any grit or dirt would have blown out the exhaust once it fired up. I was thinking about pouring some oil down the spark plug hole or hitting it with some fogging oil for good measure. What else can I do to make sure my crank bearings don't get ruined? Thanks
