filteredsoul
- Jan 8, 2002
- 7
- 0
If I install the Cometic .012 (half thickness) base gasket on my 1999 CR125 to increase bottom-end, this will effectively increase compression correct? Currently I use 93 octane pump gas. Should I use 100 octane pump "race" gas? There's a Mobil station that has this stuff. I wasn't sure if the increase in comp. would require higher octane fuel.
