canyncarvr
- Oct 14, 1999
- 4,005
- 0
The cylinder/piston are matched sets based on these designations. The piston is stamped on the crown, the cylinder on the LH top (visible with the engine together, in the bike).
If you do a top-end job with an OEM piston, you might have a prolem.
Example: My kdx is marked 'C'. So is my riding buddy's.
BUT, if you order an OEM piston, you don't have the choice of which tolerance marking you get. You'll likely get a 'B' if you order a stock kawi 200 piston (if you have a 220, you don't WANT a stock kawi piston!). I got a 'B'.
That's a problem. You need a 'C' piston for a 'C' cylinder.
Put a 'B' piston in a 'C' cylinder,and you'll be within spec...but on the edge of the range.
My piston/cylinder clearance was .003, and the ring gap was .012. A 'C' fit would have been better.
But...I already had the parts. Don't have the time right now to wait on an EG 225..my cylinder needs to be replated anyway, so who cares if the piston isn't a perfect fit? Not me!!
And even so...it DOES run so much better!!
Wow. What a bike!!
IMO???..check your tolerance markings. If you don't have a 'B' engine, don't buy an OEM piston.
Wow. What a bike!!
