canyncarvr
- Oct 14, 1999
- 4,005
- 0
1. The pivotworks kdx ('H' model) swingarm set replaces the four 20-27-15 oem bearings (two each per side) with TWO 20-27-30 ..or so...bearings.
Anyone with a point of view on the advantage/disadvantage of a single replacing a double?
While the pivotworks bearings are indeed the same length overall, the oem bearings are installed with a space between them. Kinda' makes their 'effective length' quite a bit longer?
I put them in close to the outside edge of the swingarm. Probably should be on the INside edge?
2. Just got my LIFETIME WARRANTY rear wheel bearing set (with seals) from CBR. Can you imagine? A lifetime warranty on a dirt bike wheel bearing??
Neither can I. ;)
***edit*** This just in from CBR. They do have a 20-27-30 bearing (caged) that would work in the swingarm. $11.95. You would still need sleeves from kawi if you went that route.
Neither can I. ;)
