jonnyriabov
- Oct 27, 2005
- 90
- 0
I winterized my 2004 yz 250 at the end of last season
-fogged the cylinder,
-drained the tank,
-cleaned the carb
-changed the tranny oil,
-cleaned and left the filter dry
-greased all the bearings
-and kept it indoors all winter (cold-hot mix of temps)
It was running perfectly without a flaw when I put it away....I went to get it running this week, and it started up perfect, and has its usualy awesome power, but.........It refuses to idle, and has a terrible bog when leaving idle, Infact it will run just fine with the choke on (only starts with choke when warm as well)
The only thing different on the bike this season is I added an Hour Meter.
I have so far to try and fix this problem:
-Recleaned the carb, all holes seem to be flowing freely
-Changed to a new spark plug
-Checked my reeds (look like new)
-Checked my TPS ohms (seemed to be fine)
-Tried two different batches of mix, just incase I over mixed the first batch of fuel.
-Put my stock silencer back on
-Swapped airfilters incase I over oiled the first
Im sooo confused right now, as the bike runs just fine past the bog, and no matter what I do with the pilot screw nothing helps. Could it be the cold weather.....-2, Is it possible my powervalve is stuck from the fogging oil,....or should I clean my carb for a third time? Could the TPS be messed up from letting it snap to fast when reinstalling the carb slide?
Anyone who thinks they can help....please reply as I really want to figure this out without bringing it into a shop.
jonny hard luck
-drained the tank,
-cleaned the carb
jonny hard luck
