pete fry said:I understand I should bleed the air from the forks after every ride.But do you put the bike on the lift so the forks are fully extended or when the bike is sat under its own weight???
CaptainObvious said:I see from your signature you have a 1990 KDX200. Does an "E" model KDX have a bleeder valve? I think it has a solid cap.
Xtremesports445 said:Not meaning to thread jack, but are the bleeder screws the ones that are next to the compression/rebound (can't remember which one is on top) adjusters at the top of the forks?
