ZKDX
- Aug 23, 2002
- 309
- 0
I've read quite a few threads about how you should check float height when you have fuel running out of vent lines while parked. Well i followed my manual step-by-step for checking my float height...used a tube connected to my drain, held beside carb visually check height of fuel in tube---manual says .08 from top of bowl to fuel height, well you can easily get anything you want just from moving bike, carb, or tube a little......anyway my question is: Is there a good article or thread telling the specifics of setting your float height.. i was going to just bend my tang down, but i have no idea how much, I know there must be an accurate way of knowing how much to bend the tang
