I was reading all the fork conversion posts and found one answer, but not the other so here it is.
2004 KX250 forks and triple clamp on my 2005 220.
The stem has been swapped out from the 220 to the KX clamp. There is too much slop side to side. (the top of the stem, and the center hole of the top clamp)
The shim/washer idea seems to remedy the up and down problem, but not the other.
Any ideas appreciated.
Update: I'm having a collar made.
