The rebound damper adjuster (bottom one) is set up so that when it is fully clicked clockwise, it's at it's hardest setting. 16 clicks counterclockwise is the useable range, the more clicks counterclockwise, the softer it gets. Same thing goes for the compression damper (top one).
