What spark plug to you run? I know there is some special NGK one that is recommended but its costs heaps, I just run a BR8EG. what do you run in your RM?
I always ran the special plug. Since the bike was jetted clean, the plug was only changed when it was worn out after 6-8 months of use. I used to buy them for about $18. $36 bucks a year was no big deal. I carried a br8evx as a spare, but I never needed it. This was on a 1999 RM125
They recommend a certain pre-mix, fork oil and chain lube but I dont follow that either :-)
They also say you can run 90 Octane pump gas (barf) ya right , hehee
Seems to be a nice fancy hand made plug. When searching this plug on a NGK's site they say it is for 1996-2003 RM125's concidered to be the "ultimate class".
bingo your right on the noise the factor plug is a wire tip and cost lost I,v had lost of bikes that called for that stile but run the b8es, or egs works and runs great
