I have here a fork and a shock that are quite exotic to me.
Brand-name is API, since the clickers are labeled in German I suppose the stuff is of German or Austrian manufacture.
Fork: It is an inverted fork with 42mm lower tube diameter, compression damping in the left leg, rebound in the right. The fork has no springs and works with air pressure only. Triple clamps are billet.
Shock: The shock looks a bit weird, too. The spring looks rather weak and the piston shaft is about twice as thick as on a standard shock (I guess around 30mm diameter). It seems to work with adjustable air pressure, too.
These parts are mounted on a KRAMER 450 twostroke (model year around '83) but at least the fork wasn't stock equipment back then.
Can anybody help out with any information (tips, documents etc) about that stuff?
