Hey, I just had MX-tech in livermore CA. change my springs on my 2002 cr125 to suit my weight (125lbs). My problem now is the valving is to stiff and I am turned all the way out on my compression on the forks and low speed on the shock. I have done my homework and I'm planning to switch to 2.5 weight oil in the forks. Should I change the oil in the shock to? Anyway my main question is how will the change to the lighter oil affect my current clicker settings. Can you give me a ball park recommendation on how to adjust the clickers to comensate for the lower viscosity? I appreciate your help.
