On the ol '87 KDX the base gasket after a few hours will poke out the front and cause an air leak. Anyone else have or had this problem? Solution. Is there a good sealer that will fix this and still allow the cylinder to be removed later?
permatex makes a product called hylomar its blue sticky stuff that does'nt harden at all.removal is painless wo'nt leave any hard to clean residue and will hold any gasket from blowing out it is really good stuff.
