t_mihalenko
7
Base Gasket wont seal on new rebuild
Base Gasket wont seal on 2003 RM 250 new rebuild. I have tore the bike down again and replaced the stock base gasket with a aftermarket base gasket. Got the bike all back together and it still barely leaks. The bike is producing around 245lbs compression.
I would really appreciate it if someone can help. I don't understand why im having this problem. The whole engine is brand new. New weisco piston, crank, L,A, Sleeve cylinder work, bearings etc...
Studboy
Thinks he can ride
Dec 2, 2001
1,818
There must be a place on either the cases or the cylinder where it is not perfectly flat or is warped.
I would check that out, and if you can't see anything, I would try spraying 4-5 coats of copper coat on both sides of the base gasket and trying again.
