Have a 91 KDX200, pro circuit pipe and silencer, boysen power reeds, 152 main jet, 48 pilot, head is brand new, and cylinder is a used one picked up from kaw shop, mine got wrecked,removed the airbox cover, and well i recently put it back together from painting the frame, rode it around, then checked it and noticed the base gasket was leaking on the right side (sittin on bike) thought maybe the gasket had tore, happened once b4 so i tore it apart, and the gasket was fine, so i replaced it got it back together rode it again and the same thing, one thing i noticed is that the bike vibrates a lot more with the air box cover removed, and the only thing i can think of is that maybe the cylinder is warped or the bottom end mating surface is warped, and it seems to only really leak out when you really get on it, rev it up a lot, weird thing is end of last summer i had the same used cylinder and didn't leak, but now it does, the only change from end of last summer is jetting and air box cover removed, i was thinking of just using some gasket sealant but didn't really want to go that route, any ideas?
