I have an 03 yz250 that had a base gasket leak...replaced gasket leak again... rtv fixed left side...right side leaked. What gives? The leaks are directly under the transfer ports where the gasket gets real thin. When I replace this time I will check for flatness and also apply yamabond to both sides.
I know of at least one other person that has this same bike with the same problem. The gaskets that I am using are OEM.
I have never encountered this problem with any other rebuilds on this bike and now it has happened twice. Do yall use a seler on your gaskets??
