What brakepads and chains to use for longest use?
Once everybody around here used OEM Kawa pads,also on other bikes if they could be used on the other brands.What do you use?
I like the Sidewinder Ti series chain and sprocket.... The whole setup will set you back about $300. I am using it on my 426f with almost no visible wear. I do recommed taking the master link apart once inawhile just to lube it. I don't think master-link o-rings seal as well as the rest of the chain.
Any good name brand X-ring chain will work good. For pads, I use EBC kevlar pads. They don't stop as good as the stock OEM honda pads, but they last 10 times longer. Honda brakes are still good with aftermarket pads.
