yfzut
i have a 02 yz 426 in a 05 yfz450 chassis and i want to do a big bore and have the crank stroked but dont know who to do this. just need to beet the hopped up 450 quads.
SFO
2,001
Big bore is as easy as clicking on the Eric Gorr icon on the left.
A stroke is not as common a upgrade.
To keep the current rod ratio a stroker plate and custom cam chain will be in order.
You can make mid 50~s with a well built 97mm motor.
This will give the other built 450s a good run.
Falicon will probably do an offset crank pin as well as powroll.
