I need some major advice on my kid's 2000 X3.
We got this bike in December, and my kid has had it out about seven times since. It always ran OK, although it did seem a little rich on top, cutting out and bogging a bit at WFO but nothing serious.
Well, the last ride out, his clutch went. (His bike also seemed to be cutting out more than before on top.) So, I replaced the pads. When doing so I cleaned the air filter and noticed a big crack in the airbox. Mud, dirt and weeds had found their way inside and down into the carb.
I cleaned the carb and put everything back together. Now, though, the bike is running incredibly rich. It will barely idle with the screw all the way in. It won't pull me (~170 lbs.) on a flat surface, bogging and sputtering when the throttle is cracked open. Pulling up the choke immediately kills the engine. It spits oil out the silencer like there's no tomorrow. If cool, the bike runs OK for about 15-20 seconds when first started, with no spooge out the silencer and it has good power and no bogging; after that, though, it's hopeless.
With the fuel metering screw all the way in to 1/2 turn out, it seems a little better, but not much. I dropped the needle a clip, again, little if no help. Just for the heck of it, I put in a bigger main -- I don't have a smaller one right now -- and that made things worse. I've had the carb apart about half a dozen times and can categorically say that it is clean.
Right now the bike -- it has a 21mm carb; the previous owner removed the reducer -- has a 94 main, 262 needle jet, W3 needle in second clip. I can't remember the choke or pilot jet, but don't think they were far off stock.
My questions are: Can this thing be so sensitive to temperature that the 15-20 degree difference between before his clutch went and yesterday make it run this much worse with the same jetting? If not, does this sound like a bad right side crank seal? If I'm looking at a seal replacement, can I get to it without splitting the cases?
I would just order the new jets and rule that out myself, but I'm tight on time. This kid will already miss two races thanks to this and I have to get this figured out by Saturday, which means I need parts ordered today. If anyone with experience with these things doesn't think the jetting could make it this bad, I'll just order the stuff for the seal replacement now.
Thanks,
James
Thanks,
James
