darringer
- Dec 2, 2001
- 1,029
- 0
Yes, cars do run differently in different weather! 2 stroke bikes are alot more sensitive to weather changes. When you talk about -25 to +25, you're talking about a 50 degree swing! Quite a big difference. You say the plug is wet and black. It's telling you either spark is weak, or jetting is off. Maybe oil is separating from fuel at -25. I would try a new plug 1 step hotter. The plug might not be retaining enough heat to burn off the oil and stay clean. I have never had good luck cleaning plugs and reusing.
