I have a 2001 KX 250. I ride in PA which is mostly between 1000 and 2000 feet above sea level. Lately I have been running Maxima Castor 927 at 32:1 with 94 octane pump gas and a B7ES plug. I changed the jetting to improve the throttle response and to clean up the black spooge coming out the silencer. I read that spooge is usually caused by a rich pilot. I went two sizes leaner on the pilot (52-48), one notch leaner on the needle (2-1), and one size leaner on the main(160-158). I have no problem with how the bike runs now, but no matter how I adjust the pilot/air screw, I still get the black spooge, and I am hesitant to go three sizes leaner on the pilot. I am thinking that since most of the time I run the throttle in the needle stage that I will try a leaner needle setting. Since I am at the leanest clip position I will need to get a leaner jet needle (NAFF- NAFE). Is there overlap between jet needles, and if so where? ie:what clip position on a NAFE needle is one step leaner than #1 on a NAFF. Do you think doing this will clear up the spooge?
