from what I read the blader fork has 2- volume displacers 1- being the cartridge rod. On a the non bladder forks this displacement of oil (by the cartridge rod ) goes through the base valve. But on the bladder forks it is absorbed by the bladder chamber. 2nd volume displacer is the inner tube charge entering the outer tube. Question 1-is the volume of the oil of the inner tube entering the outer being displaced passing through the base valve or is it still by the cartridge rod. 2 -how or does this change the thought on mid valve floats on this type of design. trying to better understand what is actually going on here.
