Went riding in the mountains yesterday at 8,000-10,000' elevation. I'm jetted for 6,000' and expected the bike to run rich, but it seemed to run fine all day. No bogging, no plug fouling, no problems at all, so I left my current jetting (148 main, 38 pilot, needle all the way down). However, when I was loading the bike on the trailer, I noticed some oil on the swingarm. At first I thought I'd blown the shock but after tracking the oil, I found that it was dripping from the drain in the airbox. Popped the seat and sure 'nuff, the airbox is coated with oil, plus I can see where small pieces of foam are sticking out from the air filter. Up front, there's some spooge dripping from the exhaust- not normal on this bike as I have gasket sealer up there.
My riding alternated between putting along in front of an ATV and XR80, and hammering it down open roads and up steep hills and such. I also did some major uphill climbs followed by- you guessed it!- major downhill grades. We're talking miles of uphill, turn around, miles of downhill. On the downhill, I tried to keep the engine buzzing, but there was no real load on it. My guess is that the bike was running rich, building up oil, and then blowing this back a little bit when I had opportunity to hammer it, or the long downhills let it blow back.
When I get a chance today or tomorrow, I'll check the reed
valves, and remove the air filter to look at it. I'm also going to order some leaner main jets for next time (148 is as lean as I've got and the charts say 145 might be better).
Any other suggestions?
