Anybody have any suggestions. I'm working on a friends (hammered)1989 Kx250. I rebuilt the top end along with all new gaskets. After I got it back together and started it, white smoke just billowed out the exhaust. It did this before I took it apart along with barely having any compression. My first thought was head gasket leak, so I removed the head and sure enough it had coolant in the cylinder. I had my machinist check both head and cylinder for flatness and they are fine. It seems that the metal gasket is not sealing properly. After 2 new headgaskets I'm ready to, eventhough I don't like to, throw a thin bead of High-Temp
silicone on the cylinder and head and "hopefully" call it good. Any help would be appreciated.
