djj624
Hi just rebuilt an 02kx 125. had the cylinder replated, and brand new wiseco top end and gasket kit, this is not the first time iv done a top end kit on a 2 stroke so im not a novice.. Got the bike all together started up second kick ran great right before it died and would start back up. Checked the plug and it was wet with what seemed like coolant. Popped in a new plug and she started first kick and ran for quite a while after with no problems... Then fouled another plug that was all wet. At this point i figured head gasket so i replaced it with the old one which seemed to be in good shape and a thin coat of permatex till i get the new one in but im having the same problem... Any ideas. i did also check the head and cylinder for warpage and they are both in spec...
