I have a 1970 Suzuki mt50 trail hopper 2 stroke.it has a [posi-force Lubrication] system,.I can't find the cable for it ,so would i do any harm to the engine if was to bypass the oil pump and just put pre mixed the 2stroke oil in the gas tank.?
leave it together or it will suck air through the seal in the case
plug the cable hole up
disconnect the oil line ,and plug it mix up some premix ,and ride
