RM85rider123
681
hey, I am going to go get fuel tommorow, and I have the chance to get racing fuel. I am thinking about running cam 2 110 octane. Would I have to do anything to set it up for race gas? (besides jetting). Oh yeah, it's a stupid question, but would 110 octane be to much for my 85? I know how high octanes corrosponds to higher compressions, so would it handle it? Thanks. :cool:
RM85rider123
681
_JOE_ said:
Any reason you want to run higher octane fuel?
just to add a little bit more power. I know it doesn't increase power that much though. I'm just doing it for fun.
IndyMX
Crash Test Dummy
5,548
Amo, IN
Unless your bike requires the extra octane, you won't see any increase in power, just a decrease in the amount of money in your pocket.
RM85rider123
681
really? my compression is getting somewhat low, so would that give it a little bit more power? BTW, I'm not worried about the price. Speaking about the price, about how much does it cost a gallon?
Low compression can't be fixed with race gas. You need to rebuild it. Higher octane is needed in engines with HIGH compression, not to make up for lack of compression.
RM85rider123
681
so it would be a bad idea to run race gas right now? And the compression is not that low, but I will be doing a top end job here soon anyways.
IndyMX
Crash Test Dummy
5,548
Amo, IN
compression ratio is what were talking about here..
Look at it this way, does your engine knock with pump gas? No? then you don't need the 110.
If you run 110 right now, it won't do anything bad to your engine. But, you will not get any more power out of the engine. You also won't see any power increase if your engine was in perfect condition with race gas. Unless it was a high compression engine, requiring race gas.
When your engine is built for it, you don't get the power from running race gas, you get the power from the fact that engine is built to produce more power. Which requires you to run the race gas.
RM85rider123
681
ok. Thanks for the help. :cool:
RM85rider123
681
I got one more question......... is it alright to run leaded race gas, such as the 110, in MX bikes? I know it is not good for 4 strokes, but what about 2 strokes? thanks.
