thejake456
- Sep 24, 2007
- 219
- 0
i have been looking on bikebandit.com and cheapcycleparts.com for the ile screw on a 2001 blaster and cannot find it! i do have a aftermarket 30mm. trenda carb. will that work on the blaster???
That is a must! Then you have to figure if length of the slide pull is the same, or close enough to adjust. If it did not come with one, and will not idle now, there is a mechanical reason it will not idle. Timing, carb, air filter, something? Even for a quad, I am guessing that stock carb is better than that french carb._JOE_ said:Does it fit in the air boots?
thejake456 said:that didnt help out at all. what is the exact name of the idle screw???? and i really want to know if that carb i have will fit it???
