Have tore carb completely apart,and changed needle
position twice down both times,tried different pilot jet,
pulled reed cage and examined with it being ok.Still can
not figure out why the engine just runs on when coming
down to idle.Have tried changing timing with no change
that I could tell,different plug,different gas,and it still does
it.Have tried propane torch with just propane around flywheel
and couldnt hear anything differnt.Is it a air leak or could
it be a exhaust valve,head gasket,crank seal,ect?
please help or give suggestions or test that you would try.
overbore
overbore
