gwcrim
- Oct 3, 2002
- 1,881
- 0
Some background info: I'm pretty good with carbs. I have an '89 KX500 with a 170 main and 60 slow jets. I live in the upper Ohio River Valley, elevation 1000', temps 35-55* and I've been using MX2T @ 40:1.
When I bought the bike it wouldn't idle. Easy fix: adjust the idle speed screw. That worked but it was nearly all the way in. So I adjusted the idle mixture screw from 2 turns out to 1.5. That really didn't effect the idle much. Not as much as it should have IMO.
Most carbs I've messed with leave quite a few threads showing. Maybe it's just the colder/leaner air, but I thought I'd ask:
Is it common for the idle speed screw be nearly all the way in?
