01 honda cr250 with 38mm Mikuni TMX carb and its leaking gas..at the Honda parts deparment said it was the float needle and i change it, but it still leaks gas .........any suggestions
i cleaned the carb and changed the float needle that the salesman(not mechanic)said was the problem...but its still leaking from the over flow tube and now i've wasted about $30 for the needle float that wasnt the problem.......can anyone help me out? thanx
Put the float in a bowl of gas and see of it floats. If it doesn't get a new float.
It should float about half of it's mass above the surface. If it's brass shake it and listen for fuel inside. If it's the black plastic type they get heavier with age.
