Please HELP!!! My buddy and I spent all day trying to tune his '95 XR600R and have hit a wall. The bike is running great at idle and from mid-range on up. I mean this thing is running perfect and pulls real strong. The problem is that when the throttle is at zero (fully closed) and then you whack the throttle open, the bike coughs and dies or hesitates until you let off a little and then takes off like a shot. If the throttle is slightly open and then you whack it, off it goes. The problem is only when going from fully closed to fully open.
What's worse is that the bike has the ability to be put in a partial choke setting. On partial choke, the off idle studder seems to go away, but of course, the rest of the circuits run like crap. What gives?
Here are some specifics:
'95 XR 600R
Stock Main 152 - Currently running a 162 (Changed due to the addition of a 4" Supertrapp Silencer running 6 restrictor plates).
Stock needle clip position is 3 - Currently set at 4 as a test but was no better than at 3.
Pilot Screw is currently 2 turns out-don't know what stock setting is.
Everything else is stock.
The bike is being ridden is Michigan, roughly 500 to 1000 feet elevation, 75 to 90 degrees, 50 to 100 percent humidity.
Please HELP!!! Is there any way to cure the off idle studder?
Thanks in advance for you replies!
Jeff
'95 XR 600R
Jeff
