Use a rag soaked with engine oil and followed by some spray carb cleaner and clean rag. Or a low pressure glass bead blaster, be careful though to not hit the sealing surface of the head or you will be planing it. If the carbon is crusted, use a pocket knife carefully to get the big chunks loose.
There are other waysbut, I've always found these methods to be best.
