A couple of questions that have come up since I bought the bike,
I am fairly new to the sport but I have a good mechanical sense
so if anyone can guide me in the right direction I would be stoked.
Firstly how many turns from seated should I wind out the air/fuel mix screw? what are people talking about when they say needle setting in 1-2-3 position etc?
the bike seems to have a nasty flat spot when I first give it some gas then it seems to come good, any clues?
What fuel mix should I be using is 35/1 ok.
what is the best crankcase oil to use?
should there be any freeplay in the clutch cable?
there is a crankcase breather very close to the filler hole without a tube on it, should there be a tube and where should I route it?
As you can see I'm a little lost and all I want to do Is jump on the thing and get riding, cheers, Heath.
ps its a 91 kx125
ps its a 91 kx125
