RoadDawg
106
I have 2 KDX 220's. One is a 98 and the other is an 03. I am going to get knew sprockets and chains soon. I am going to stick with the factory 13/47 sprocket configuration. The chain specs are 520/108.
I've been looking at Renthal sprockets, but they have only 48 tooth rears (smallest). Will this make a difference on my chain size?
What's a good brand 0-ring chain? I'm not looking for more torque, but I do expect the 48 tooth rear will change that a little.
Any other input on chains or sprocket makers would be appreciated.
IndyMX
Crash Test Dummy
5,548
Amo, IN
Most chains come with 120 links.. So you're going to need to cut it down anyway.
I doubt that you will notice a 1 tooth difference in the rear.
Regina makes a damn fine oring chain
Joburble
Bring back the CR500
417
Hi RoadDawg, Renthal do make a 47T rear or at least their website says they do 'See it here'
The part number appears to be 112U-520-47GESI
Anywho, if you do go with a 48T and want to see how much of a gearing change it will make you can download an interactive Excel spreadsheet that will show you from 'Here'
FRESH VIDEO
