i need to take 10 links off my chain. i dont have the chain breaker tool. what could i do to make it work? do you guys use a couple different tools? any particular method? thanks.
What I do is carefully grind down the pins enough so that the links are weak and can be easily pried off. It takes a while since you have to be very careful but is a cheap way of doing it. :)
