I have a 300exc with the WP fork. I decided to change the oil in the forks the other day (first time I've changed fork oil). I drained and pumped everything out then filled up each with 750cc like the manual stated. Now when the forks compress 2 things are happening.
1.) There are some clanking sounds that were not there before. They are being caused by the very top plate in the forks (right under the cap) colliding with the cap. Should there be some sort of spacer in there? I didn't take the forks apart so I don't see how I could have caused a problem.
2.) On hard compression (like a jump or log) some oil seeps/squirts out the compression adjustment screws. When the screw comes up to release the air, some oil comes out. I assume this is just the forks getting rid of the excess oil they don't need. Is that correct?
What's the diagnosis doc?
