Choke problems on a PWKa/s Help Please
I recently changed from a 36mmPJ to 38mmPWKa/s. I have the air screw out 2 1/4 turns and adjusted the idle low when the engine was at running temp. When I pull the choke and start the engine when it's cold, the engine races very very fast. It'll start even without the choke, it will be just a little faster till it warms up.
I don't what to blow up the motor when its cold.
I ordered a DSP Power Now, but now I'm afraid it will make the problem worse.
I did have to turn the idle screw in a lot to get it to idle at all.
Does this mean the pilot jet is way to big? :scream:
48PJ 1468Needle 168MJ 1998cr125 FMF fatty, Rad Valve
