Can I fun some atf in the clutch case for a couple minutes to free up some of the nasty thats in there ? Then drain it and fill with a better lube. Will this be ok ?
I've run atf 'TYPE F' tranny oil in my bike plenty of times. It works as well for a transmission fluid as any expensive oil you put in the bottom. But also remember that I change my transmission oil after every ride...
