I’m in the same position. What I did was use carb cleaner and my air compressor. I had the entire clutch assembly out and sprayed everything spotless, then blew it all dry at low pressure. Don’t use a compressor unless you have a moisture regulator, and don’t blow against the gaskets. I was flushing the motor looking for two micro bearings from the throw out bearing, (4 were still in the basket); I later screened the oil and found them. After cleaning, I sprayed everything down with fresh 10w40 oil.
Good luck,
Dave
