New to forum. First time into removing KDX 220 clutch basket. Any ideas on getting nut off!! I assume everyone has experienced this. KDX is different that other baskets I've removed. :bang:
Either a flywheel holder or an impact wrench will do the trick. You can pick up a flywheel type holder at your local Scmucks auto supply for about 14.00.
grabb it plyers are greaaat - try dennis kirk,and rocky mountain- some clutches still need the plyers to hold the inner hub--
they work for other things 2
