I have a 1996 RMX 250 when you pull in the clutch when its in gear it won't roll, it seems to shift fine when I'm riding it, FYI just changed tranny oil, and clutch cable but, it had the same problem before this.
You're saying that when the bike is not running, and you try to push it when it's in gear with the clutch pulled in it won't roll? I would guess that your clutch just needs a slight amount of adjustment.
